G62 code
Good afternoon. Wondering if anyone can help with wiring pin ours for the coolant temp sensor on a mk1 fabia vrs . I have tried 2 new genuine sensors . So believe it to be a broken wire .. I get code intermittent short to plus g62. I’m guessing the positive wire has a break … also should it be 5v signal ?
thanks In advance
tony
  • Sponsor
Year of car? ASZ or BLT engine?
It’s 2003 so asz .
thank you
  • Sponsor
Pin 1 at sensor blue wire to pin 112 at engine ECU, pin 2, brown wire to ecu pin 104. :thumbup:
Thank you very much .. from the research I have done . I believe they go direct to ecu .. ?
  • Sponsor
Yep, direct
