Heater fan not working
Problem with 2017 manual AC. The heater fan stopped running last week. Any common faults to look for? Or just to start tearing down too search for reason?
Check the fuse?
Checked. OK.
You may have better luck if you post on the Superb forum.
The brushers often stick on these motors also they ware down. It is an easy remove from the passenger foot well
John
Problem (temporarily) solved.
The brushers were stuck. it's now spinning again, but will be replaced soon.
