Bit fields with vag-com (vcds.exe) spaces in
Hello friends, I will ask the masters to the vag-com/vcds.exe. The encoding of the daylight headlights that are open by the hand brake, the encoding can be done in the PQ35 platform (may also be the same in PQ25) in the list;
Quote
(09-Cent.Elekt.->Coding->Long Coding Helper->LCode2 in Bayt 11, Bit 0 checked)
The screenshot in the relevant bytes of the PQ35 platform is as follows; VCDS.exe
As it appears, the opposite of some bites are empty, they are not clearly evident. So in the form of hidden encoding. When we know that byte 0 of this 11, when the 0 of the 0 of the 0th bit is marked (1 when 1), the daylight lights are going out. If you have those who know the meaning of these and similar bits of bits that are not specified in this regard, I would be glad. In the MQB platform, encodings are more difficult and common in the old model PQ25 / 35s, it is a little more difficult. For example, in a Scirocco yesterday, the rear signals were burned with stops, could not pass through the examination. I didn't find a line on that. Since I have the same platform as my Yeti, my 1) is fully copied to the code opposite and select Scirocco as the type of signals returned to normal.
I ask the meanings of 0, 1, 4, 5 and 6 Bit, which is not written in the visual. Probably 0 of the 0th bit of Bitin can be an effects as it is in the relationship between the DRENI-DAY rumor (DRL). Like the corresponding STOP's back signal in my previous message.
I'm sorry if you have an error in Google translation!
