Rear window de-mister
Has anyone had a problem with the radio cutting out when the rear window de mister button is pressed on? done a full scan and no fault codes coming up
cheers
Seen this on some Audis - the rear demister is also used as an aerial and there is a filter that separates the radio signal from the demister power, when this fails the radio signal is lost when the rear demister is turned on as you describe.
That’s a bad idea when it goes wrong imo any idea on a fix? Cheers
Only way I know is to replace the filter.
How hard is that to do?
As you can see from my signature I no longer have access to the Octavia 3, so I'll have to let current owners comment ...
