Stereo Surround replacement
Guys
I've changed my stereo to a standard double din one
I've got the plate which makes it a VW shape!
What I need help with is Skoda!
They cannot find the correct surround part number so I can order the one with the smaller aperture (not the Bollero size) - I beleive it is sat nav size?
Does any one have one fitted standard? if so, any chance of giving skoda a reg and asking for the part number? or if you happen to have the correct part number...
Skoda seemingly can only look this up against my reg.. which has the incorrect size as standard
Grateful for any help
Andy
It should be in here... somewhere!
https://7zap.com/en/
Thanks mate
I've had a good root round, but they only list the same one as Skoda described which is the aftermarket faschia
Might be worth adding a picture of your old surround along with the full part number including colour code (stamped on the rear).
Should be relatively easy to figure out from that.
I've linked below to an ebay auction for what I beleive is the correct 'type' of item
I'll do a bit of research, but this looks correct
https://www.ebay.co.uk/itm/173518766439
Brill find, thanks
I think I've actually found exactly what I was after all along on there...
https://www.cars-equipment.com/en/shop/plastic-trims-52/oem-1z0858069dkdf1-navigation-aluminium-trim-for/
Is this is OEM part code? - OEM 1Z0858069DKDF1
If so, I'd probably try Skoda in the UK to avoid all the post brexit import BS
I tried one of those plastic infil kits, and they are aweful.. so flimsy It went back.. hence this original route..
Appreciate the help
@AScoff
Plenty on the bay for cheap, just search the p/n 1Z0858069DKDF1.
Thanks - I have tried that, but they are all 'seemingly' the standard ones, and not the smaller opening ones which woud be suited to a Skoda Satnav unit
I thought you were looking to fit a standard double din.
The search criteria I mentioned all show what you previously specified as correct.
Edited by MicMac
