Nav volume question.
Sure this will be old question to most, but not to me!!
2015 Yeti L&K
To get the nav display to work you have to press the "radio" ON button. Clearly, the radio then starts
First part of question, how do you switch the radio OFF!!!
Now select NAV, all fine now I've tamed it, but the bl88dy radio is still on in the background, and if turned down low enough to not here the thing, it's too low to hear the sat nav directions.
SO, Second part of question...........I don't want the radio, at all actually (!) but want to hear the nice sat nav lady.
Surely this must be possible, but hours of reading the owners manual so far hasn't even told me how to switch the radio OFF!!!
Any ideas please. Delighted with the car in all other respects, just this one!!
Edited by john999boy
Adjust the nav volume as it's 'talking' as it's different to the radio volume.
  • john999boy changed the title to Nav volume question.
Thanks JB
Tried that and even got into sat nav settings and turned the radio volume (I think) to OFF, but still get radio when sat nav in use.
I simply cannot believe how difficult this simple need is!!
You should be able to turn the radio volume down to off then press the right button when a route is set to get the sat nav next direction audio and adjust the volume to what you want.
Thanks Urrell
Next thing to try then, even printing this to save several journeys to the car!!
I
Thanks seems to work, will try next drive.Ks I
