2014 Monte Carlo 1.2 Tsi
Hoping someone can give me some pointers before i take the car to a garage and get ripped off.
Bought a 2014 Monte Carlo 1.2 TSI last August to use as a run about when in Suffolk, just before i bought it the owner had the Knock sensor replaced. While driving the other day it suddenly wouldn't accelerate or pull up slight inclines. I carried out a scan and found the following.
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HK    HW: 03F 907 309 AK
   Component: SIMOS10.22AH10 5471
   Revision: --H10---    Serial number:                CVN: 63195D3B
   Coding: 00110056200400080000
   Shop #: WSC 13765 031 00051
   ASAM Dataset: EV_ECM12TFS02103F906070HK 004006
   ROD: EV_ECM12TFS021_SK25.rod
   VCID: 72EBF68DA5AB5E1947-8026
   VINID: 91D49678215A1950C10C210124DD64F8DF
2 Faults Found:
9541 - Knock Sensor 1 (G61)
          P0327 00 [104] - Signal too Low
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 5
                    Mileage: 143004 km
                    Date: 2022.02.25
                    Time: 20:33:54
                    Engine RPM: 3117.00 /min
                    Normed load value: 95.3 %
                    Vehicle speed: 73 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 33 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 13.789 V
                    Unlearning counter according OBD: 40
                    Time since engine start: 445.8 s
                    Engine torque: 145.78125 Nm
                    Accelerator pedal travel-Accelerator position: 44.82 %
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: 13.875 °
20045 - Fuel Quality
          P30C0 00 [047] - Inadequate
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 143266 km
                    Date: 2022.03.02
                    Time: 14:50:42
                    Engine RPM: 2196.00 /min
                    Normed load value: 66.3 %
                    Vehicle speed: 71 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 14.218 V
                    Engine speed: actual: 2176 /min
                    Engine load: 66.015625 %
                    Time since engine start: 204.1 s
                    Knock sensor: cylinder 1: voltage-Knock control: knock sensor voltage: cyl. 1: 0.23720 V
