Drivers Offside Window Connector
Hi i am having trouble with my driver side window switch i bought a double switch for my  Skoda because it stopped working when i replaced the switch it worked for about 10 minutes then it stopped so i took the fuse out (nothing wrong with it )  and put it back in windows worked for another 10 mins then stopped so took fuse out again and put it back in and they worked again for the same time i am trying to buy a new 4 pin connector block that is square iv only seen the oval block for it to see if thats the problem but i dont know what its called or were to buy 1 from can anyone please help
  • Sponsor
Most connector housings will have their part number somewhere on them, albeit often in tiny characters.
  • Sponsor
With this being a mk2 Fabia, broken wire(s) in the front door wiring bellows would seem like the most likely explanation for the symptoms you're seeing, I think. Grey/white wire broken would be my guess.
Edited by Pete_Ex-Wino
thanks for the info i cant see a part number on it
i have looked at the wires they are all connected but i could see a bit of the copper showing so i put electrical tape and still same i need a new 4 pin block but dont know what to look for it
i need this block even better if it had the wires connected
6 hours ago, UrbanPanzer said:
the part number of the connector is
1K0972704E
https://www.skoda-parts.com/spare-part/1k0972704c-flat-contact-housing-4-pin-30873.html
It won't come with wires unless you buy a used one cut from a vehicle loom. whats wrong with the connector ?
Thank you that looks like the correct one The connector doesn't fit tight as you can see by the pic the plastic is a bit bent plus I can see abit of the copper showing through about 5mm from the block I don't know how you managed to get that code so THANK YOU
1K0972704E
Got a connector of a seat and tried it doing exactly the same work for 10 mins then stopped working might have take it to my local auto electrician
  • Sponsor
Did you check the wiring inside the rubber boots on both front doors?
Yes I did no wires are damaged it just wired that when I remove the fuse and put it back in it works for 10 mins then stops intill I do the fuse again
my guess would be you need a new / replacement drivers door window motor as thats the "master"
  • 2 months later...
Thanks again I had another look at the wires in boot to the car frame 3 wires was cut re-joined them everything is working perfect
Everything working great 3 wires was cut in the door boot connected to the door frame
