Comfort turn signals value change no works (error 31)
Hello! I have an Octavia MK4 RS version (2021). From the one click application the result is error, and from adaptation module 9: Prompts (31) Function not available.
Unlock SFD working OK.
Any solution please?
Thanks.
Previous models required a reset of the infotainment before it would start working. Worth a try to see?
And what would be the procedure to follow? 🙂
Not too sure on a Mk4 I'm afraid.
It could be a long press on the power button though.
Edited by john999boy
Extra info.
Control unit 09 Central Electrics. I can´t change value of Comfort flasher
GetAttachmentThumbnail?id=AQMkADAwATY3ZmYAZS04YWEAYi1iYWY3LTAwAi0wMAoARgAAAzA1GpNRdl9Omfn%2B9vsYvSsHAOtOMuKUzBVHmyorV1924DUAAAIBCQAAAOtOMuKUzBVHmyorV1924DUABZW8u%2B8AAAABEgAQAEhumxP1et5AgTetRgAtPTc%3D&thumbnailType=2&isc=1&token=eyJhbGciOiJSUzI1NiIsImtpZCI6IkZBRDY1NDI2MkM2QUYyOTYxQUExRThDQUI3OEZGMUIyNzBFNzA3RTkiLCJ0eXAiOiJKV1QiLCJ4NXQiOiItdFpVSml4cThwWWFvZWpLdDRfeHNuRG5CLWsifQ.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.DW1rwKq1cr6oPVGK56-qrS6rYu55D_Gqr6qjjsOj-AGSxZGcILVYx5-Zk4uWSARst7F47CwzDGeHTMzkBO4sCrX-vdDZZ0cC7Re247i4iicM48M-uju5ovQVs1h-InVbs9CmSIhE7Of1Puw1tNfDstlQgPfBOXq0M9uDyv2IlMjhw9jkYfcKm-Ed25F0VL8AXPDHIDbrDFpoCaP5W5yj3yWpg9BPeP_yMfiQE6osm9RE8mj6uB1uefKPLZFOw7-DGTnWZWRwJa0pxO3bWbOIVWutCEz8weZwdCignsx6I4XC1YEQ7w-bSDjjN8xBzdhkfTKzErWZnKXdRK5ss-YKag&X-OWA-CANARY=k6y5brRdHUi7-Qe_FD33hKArkUFfEdoYgDOIaSqpvn46SUsN2omWdNZ66EcYO2vpy_PZ0lXlVsM.&owa=outlook.live.com&scriptVer=20220318002.08&animation=true
  • 2 months later...
Thanks.
Hola Javier,
I have exactly the same problem. RS from January 2021, on App i get FAILURE and by changing the value in Adaptation i get Function Not Available. Have you found the solution?
Thank yoi,
Mario.
Nobody helped me... 😞
