Original Microphone not working on new stereo
In these pictures I do not see microphone connection at all. Pls check if microphone (goes to pins 1 and 7 of blue plug in original QuadLock) are re-wired to the new unit. But even if it does there might be an issue of new unit supporting microphones of other specification than the OEM one.
14 hours ago, benjacontreras said:
I really dont know what to do! My new head unit is awesome but I just can’t get the original microphone work. Im quite lost of how to get this done
As I stated in your original post you cant use the original mic. You need to wire in an aftermarket mic that plugs into lead no.9 mic input on the wiring diagram.
I cant tell from the photo if the mic is a 2.5mm or a 3.5mm audio jack but if you can plug an aux / headphones into the no.9 plug it'll be a 3.5.
You will need to order one of these. - https://www.aliexpress.com/item/32868201267.html?spm=a2g0o.productlist.0.0.61183addcniB9L&algo_pvid=ff1eb2d0-261c-492e-a67a-66dcca6064e5&algo_exp_id=ff1eb2d0-261c-492e-a67a-66dcca6064e5-1&pdp_ext_f={"sku_id"%3A"65567372809"}&pdp_pi=-1%3B1.37%3B-1%3B-1%40salePrice%3BGBP%3Bsearch-mainSearch
