Rear Climate Control / Seat Heating
Hey all,
Can someone confirm this to me and whether or not it works how i describe it.
Needs to a model with rear heating and rear seat heating also
If you use the lock on the infotainment display will it lock the seat heating too?
If you lock it with rear seat heating on, will it stay on its current setting?
Will the seat heating work with ignition on and engine off?
Thank you.
The lock stops the rear seat heaters being able to turn on.
If the rear seat heaters are on when the lock is activated, they stay on but can be turned off by the rear controls. But you can’t turn back on again.
Can’t check the last question, wife is driving at the moment 🤣
You’re a gent.
thank you
Seats work with ignition on but engine off.
