Brake Disc Size Query
Hi Folks,  I have a 2014 vRS TDI Estate and I need discs and pads all round, But everywhere I look lists 3 different sizes for the front and 2 for the rear.  Is there any easy way to get the right parts ordered first time round?
Cheers!
The 340mm front and 310mm rear are vrs 245 only.
That only gives you 1 other option for the rear, which I think should be 272mm?
The fronts on the tdi are 312mm I think, but don't quote me on that one.
If you search on here there is plenty of brake size threads.
Thanks for this.
Front options are 340, 312, 276.  I think theyre 312 but not 100%
Rear options are 272 and 253...
50 minutes ago, somedudebob said:
Thanks for this.
The diesel VRS went down to 312mm front brake discs after the 2017 facelift. Before the 2017 facelift, the diesel VRS had 340mm front brake discs.
Rear brake discs will be 272mm on the pre-facelift VRS.
The Octavia MK3 has four different sized front brake discs. 276mm, 288mm, 312mm, 340mm.
Edited by Carlston
