Headlight replacement to led
I changed my halogen bulbs with led with canbus when i start my car all bulb flashing 2 or 3 times some technician says it is bulb check can i solve this
as Pete said, pop the original bulb types back in.
putting leds into a headlight unit not designed for the way the light is delivered (multiple sources instead of one centred halogen point) causes the light to be reflected out badly, causing scatter - so poorly lit areas of road for you the driver, and also glare for on coming drivers. i could explain the sciency bit about parabolas and focal points but im pretty sure its been covered 100+ times previously ;)
Yeahbut them is yellow innit!
Most LED bulbs that say they are can-bus are not and will bring up an alarm.
In the UK since last year putting LEDs in a headlight designed for halogen is an MOT fail.
Thats because its a meaningless term so nothing could be!
Its like "Heavy duty" or "CE" etc, anything they can make up to convince the unwary to buy.
I cant see what car do you drive so i will general reply.Led bulbs are flashing because control unit is testing all bulbs,you can fix that by turning off bulbs chech on VCDS.I agree with colleauges about dazzle inbound traffic so i would recommend you to retrofit
OSRAM LED.At least it passes German TÜV
