problem at low revs 1100-1200, 1.9 SDI ASY
is there a solution to this problem
  • Replies 51
  • Views 8.2k
  • Titanium_Man
    Titanium_Man
    I would say it looks like Google translate is being used, @Pete_Ex-Wino
  • Breezy_Pete
    Breezy_Pete
    Is that under a front seat? Yellow connectors are airbag related I think  so nothing to do with engine running.
  • The Accelerometer is only there for the side impact detection for the airbag system absolutely nothing to do with the engine
I changed the ECU but to no avail
I replaced the throttle valve, but to no avail
there are no errors in the ECU
the problem occurs only when the engine is cold, and on the go
Have you checked the dog-bone mounting?
the gearbox pads have been replaced, no change
when it heats up there is no problem
the head of the electronic pump was replaced, but the problem remained
Try disconnecting the fuel temperature sensor, if it's reading high then the engine will be running too lean when cold.
when you turn off the air temperature sensor, the car is fine, but a check lights up
in all forums there is this problem but there is no solution
Which air temperature sensor, MAF or MAP?
sdi has an air temperature sensor on the air filter cover, no MAP and MAF
SDI no turbo no MAP and MAF
It has an ECU, it must have a MAP or a MAF, I know it has no turbo but that doesn't mean anything for the electronics.
Definitely no MAP/MAF according to the wiring diagrams
very simple engine with a big problem, there is no solution in any forum
I put a new EGR no change
anyone have an idea what to check
could the problem be in the dashboard
ECU from where it takes speed and temperature data
does anyone have wiring diagrams for the 1.9 sdi
