90-degree bend piece for the cooler. What is the part name
So I found out I had a leak of coolant, and upon further investigation I have found the trouble maker. Yet I can't order a new part because I don't know the name of it. I was hoping one of you guys knew what this piece was called. (see attached images)
My main guess is that the o-ring inside the plastic piece died on me, it's very loose and has quite a lot of wiggle room.
Thanks for your time anyhow!
Cheers!
  • Sponsor
The part number is readily available in your second photo 1J0 122 291F
Yes. My apologies, I only realized that after I had made the post. I have also found the part itself already.
Anyhow, thank you still!
  • Sponsor
No problem. :)
In English, I'd normally call a part like that an "elbow".
But VAG call it a "Quick Acting Coupling"
