Rear springs...replace?
Just to update you all. Springs were fitted yesterday, car drives and pulls caravan fine, drove about 120 miles yesterday. In the end the bill was 312 euros. 63 plus vat for labour ( hour and half). Each spring was 98.80 plus vat. They fitted Febi Bilstein 46925 which is Specced as 1K0511115BH, as original. They are advertised on Autodoc France at under 30 euros Inc vat!!!!
Daylight robbery...
Onward and southward.
Fats
Normal French retail margin, they will have paid less than the Autodoc prix publique.
Enjoy the rest of your touring with peace of mind!
  • 3 years later...
Hi All
An option listed for Springs on AutoDoc is “Bad Road” as against normal/std or sports
Does anyone know what the difference is and are the other features in the suspension or car you fit “Bad Road” to any?
2022 superb 4x4 170 tdi estate
Already got B6 to fit
Bad Road springs are most likely springs for cars equipped with rough road package. They have a little higher riding height, I think it was 20 mm?
If you mount these springs on the rear you also have to mount them on the front side (and maybe also mount matching shock absorbers?)
How do I find the factory build for my car
Springs wise?
Springs wise?
You can open an account on "skoda parts com" and park your Skoda in the garage with its VIN number. This apparently lets you get the OEM part numbers of various parts free of charge.
"skoda parts com"
https://www.skoda-parts.com/online-store.html
Edited by Carlston
Thanks Carlson
  • 9 months later...
Hi, I looking for rear coil springs replacement for stronger ones. Now I’ve white, 3x orange and brown. I’ve mk2 estate. Any recommendations? When driving with 4 people on board car catching the speed bumps. When I going on my own without any load everything is fine, just rear is a bit softy. (I’ve replaced whole suspension front and back inc shock absorbers).
Rear springs for the Superb MK2 marked (1 White, 3 Orange, 1 Brown) has OEM part number 1K0511115DE and build code 0YE.
3C0511115AF is two up in the hierarchy compared to 1K0511115DE.
Sach 994 337 rear springs (matches 1K0511115DE)
Wire diameter 12.25mm
Length 362mm
https://www.autodoc.co.uk/car-parts/oem/1k0511115de?supplier%5B%5D=253&supplier%5B%5D=32&supplier%5B%5D=246
Sachs 994 364 rear springs (sold to replace 3C0511115AE, 3C0511115AF)
Wire diameter 12.75mm
Length 357mm
https://www.autodoc.co.uk/car-parts/oem/3c0511115af?supplier%5B%5D=253&supplier%5B%5D=32&supplier%5B%5D=246
Kilen 65059 rear springs (matches 3C0511115AF)
https://www.ebay.co.uk/itm/391130827593
Edited by Carlston
Hi All,
New here so apologies if I have missed something or am posting in the wrong place.
I have read the previous posts on this thread as I have a MK2 2015 Superb Estate with a saggy rear......
Ironically I am also moving to France next year so judging by the previous posts I should certainly sort this before moving!
To get through the recent MOT my car had the following replaced:
Nearside rear suspension arm (left)
Offside rear suspension arm (right)
Nearside front anti-roll bar drop link (left)
Offside front anti-roll bar drop link (right)
I have always had issues with the odd speed bump scrape, especially if a tyre or two has lost any pressure, but this summer holiday trip with luggage, dog and towbar mounted bike rack was too much for it. Rear was very low and towbar was regularly making contact with bumps etc.
Since those parts being fitted the problem seems to have reduced, which surprised me a little as i assumed I most likely needed new coils, uprated coils, or auxillary coils?
I'm keen to solve this problem as I am intending on keeping this car and running it into the ground, I also need to spend a small fortune getting the clutch and DMF replaced which is going to painfully expensive too!
Any tips on:
Which coils to fit/how i check compatibility.
Can this be a DIY job (what tools req'd?), or is it garage only?
Any help much appreciated!
Ross
If it's a front wheel drive Superb MK2 estate with standard ride height (ie. not lowered ride height or increased ride height), then fitting slightly stiffer rear springs such as two up in the hierarchy should solve the soft rear end problem when the car is loaded.
As mentioned in my previous post the upgraded rear springs have OEM part number 3C0511115AF.
Edited by Carlston
Recently Browsing 1
