white smoke coming from the engine after the run
hi all, before I head to the garage I though I would ask here hoping someone might have had the same issue in the past and could help?
after the engine stops sometimes there is a white smoke coming from the back of the engine (dashboard side) and not sure what the issue is, I bought the car in March and only seen it about 3 times without any rhythm. I drive the car daily to work about 20 miles with couple starts in between (gym, shop on the way back etc.). please see video. any recommendations or advice would be much appreciated! have a good one and thank you, Martin
....and with the bonnet open?
morning, firstly thanks for the reply, was waiting until it happens again
looks like there is a little pattern (if im right) it only happens when i have between 60-100 miles left in the tank and i also noticed it only happens when the RPM dont drop to 800 when the car is in neutral and on the brakes (normally when i stop on lights or whenever, the RPM drop down)  - videos on the link below. will be grateful for any advice. thanks again, martin
https://youtube.com/shorts/-0BY1yC4UoM?feature=share
Are you losing any coolant? looks a bit like a coolant leak onto hot metalwork. Maybe caused by/coinciding with increased heat of a DPF regen in progress?
You may see more with the engine cover lifted off. Looks like a oil/fluid spill onto hot engine/exhaust
thanks both, checked that on first couple occasions and both coolant and oil are on the same levels but assuming it could be a very little to no leak?
couldn't take a decent picture due to light conditions and how deep it was but there is a metal pipe leading from the engine downwards that looked a bit wet - it was in around this area.. im no mechanic so not sure which one it is but assuming its the one in the circle on the pic from google. thank you,
InsightPortal - 2022-05-20T071032.792.rdp
EGR cooler pipework I think.
thanks again for the advice! just wondering do you think there is any connection with how much diesel is in the tank? I swear to god it only happened to me when i was under 80 miles, including today? i will obviously have it looked at but to prevent that from happening i guess i should just keep the tank filled up a bit more? thank you,
I agree with Pete. Isn't there a water cooled oil cooler down there too or am I thinking about another engine?
Certainly looks like a small water leak, so small it may not show up for a long time on the coolant level.
Can you put a thin cloth or a cold metal object in the "smoke" to confirm it is water vapour.
im not sure to be honest with you.. d
i will try that if it happens today, thanks again!
like i said before it only happens when im under 80miles in the tank, do you think there is any connection at all?
