Stalling and rough idle when warm
Hey everyone, im having trouble with my vrs.
Its a 06 vrs fabia with the BLT engine.
The car will eventually when it warms up start to have a really rough idle that will inevitably resoult in a stalling.
The car will instantly start back up again no problems at all.
And the idle problem stops if i keep the reva st around 1400.
The car pulls completely normaly and works perfectly when driving around.
In the last 6 monts i changed the cam and the lifters,at that time i also changed the cranck and cam sensors i did the flywheel and cluch too, i serviced the injectors, and did the fuel filter all is good. But the problem persists.
I even changed the MAF 2 times becouse thats the one code i cant get rid off, its the P0101. But it does not seem to be connected to the problem becouse it still persists even if u unplug the MAF, the reading on the MAF seem ok aswell.
So basicly any help would be greatly appreciated
Stock EGR system?
@sepulchraveThe EGR has been removed and turned off via vcds
