Fabia MK3 Adaptive Cruise Control Retrofit
Hi,
What hardware would be required to add to my Fabia to add ACC? I already have the front assist sensor installed and am aware I will need the different stalks behind the steering wheel.
Thanks,
James
Officially this is not possible as ACC is controlled by FEC/SWaP code and Skoda does not offer such upgrade. If you know someone who works in VAG and can generate such code then it should be possible.
Similar to the code you can buy for normal cruise control but you can't buy it?
So essentially all you need is the different stalks hardware wise, then just someone to get you a code. Would a skoda/other vag dealer be able to?
