Wipers and headlights
Hello my name is frankie and i own a 2008 skoda fabia mk2 and i have a problem with my wipers the problem is that the front wipers are not working but the back one is not and the water to wash the windows is not working both sides
i have tryed putting the the onto the computer but no faults came up and tryed changing the fuses but still nothing could anyone help?
And today i started to get problems with the headlight the parking light and fog lights are working normally bit the main beam and dipped light have stopped working sinc it started it was working 1 time but now they arnt cheched the bulbs and fuses but everything is fine
if someone could help me that will mean alot to me and i cant someone who can
have the battery and charging system checked first..
Hi,
Try punctuation. Text is easier to understand.
Just to check, your windscreen wipers are NOT working but the rear one is?
Your lights might  just a fuse problem. Download the manual if you do not have one in the car.
The wipers could have a problem with the BCM - the voltage regulator in the car. My daughter had this and you can either try and solder a new relay on or get a replacement BCM. You can check the function with VCDS if you have access to one.
