New problem with my Skoda Fabia.
Skoda Fabia 1.6 tdi
Revs limited to 2000 max.
Firing on three cylinders only.
Found the suspect cylinder and if uplugged it makes no difference to the engine.
Very rough and uneven idle.
Tested the electical connection to the suspect injector and it is getting feed, however the two terminals to the inejector I am only getting 4ohms across them.
Any advice on changing the injector of the electrical side of the injector would be much appreciated.
Just replace that injector, failure is common and the only cure is to fit a new one.
Hiya mate,
Do these injectors need to be coded?
Yes they do.
