Ccza engine vrs FL.Does it have an oil pick up pipe??
Hello everyone and I hope you are well.
Due to changing out both brown and blue oil pressure switches and still getting a low oil pressure ECP amber warning on the dash,I’m thinking to drop my oil sump to clean it out.
Id like to swap out(if it even has one??)the oil pick up pump with the gauze in it which is inside the sump.
Only problem is I cannot find anywhere on the net.
So I thought I would hit up the trusty Briskoda Forum to hopefully help out with a part number.
I’m also going to change out the oil and filter again so that will be the 3rd time doing that since I’ve bought the car 9000 miles ago.
Thanks so much.
Oil pick up pipe with the gauze not pump
As always Pete.You legend.Thanks again.
Like the new username Sir 👍
