Mk2 Octavia VRS front suspension (I know, again)
Hi,
sorry to ask about suspension again. I appreciate there is a lot on the subject but I still can't find the right answer.  I need to replace the front shocks and springs with the OEM or OEM equivalent. So far I have concluded the VRS as the 55mm strut diameter and has the 'sports suspension' as it is lower from factory by 15mm compared to other Octavias. Can someone please link me to a correct OEM set up for shock absorbers and springs? Think I have found on autodoc the correct bilstein shocks for 'sports suspension' but still struggling on springs. What are the correct height for the springs for the VRS?
Pulling my hair out with all the different springs.
If someone could link the correct springs that would be fantastic!
Car is 2011, facelift, petrol, hatch with manual gear box.
As you can see in the charts below, the OEM part numbers of the springs and shock absorbers depends on the car's build codes that the car left the factory with, ie. what parts were used in building the car.
You can obtain the car's build codes from "erwin skoda" for about 7 Euros, or there's an Italian ebay seller "VIN skoda decoder" that will provide the build codes for about 3 Euros.
You can probably find suitable aftermarket parts without the build codes, but they might not match the OEM part numbers exactly. They might, but you won't know without the build codes.
Springs and shock absorbers for 2011 Octavia MK2 VRS, Petrol, Hatchback, Manual Gearbox
Front springs 1K0411105DA 1K0411105DB 1K0411105DC 1K0411105DD
1 1K0 411 105 DA coil spring
3 paint marks
1 paint mark
red
grey
2 PR-L55
(1) 1K0 411 105 DB coil spring
1 paint mark
1 paint mark
1 paint mark
red
white
violet
2 PR-L58
(1) 1K0 411 105 DC coil spring
1 paint mark
1 paint mark
red
violet
2 PR-L59
(1) 1K0 411 105 DD coil spring
1 paint mark
2 paint marks
red
violet
2 PR-L62
KYB RH3941 front springs 1K0411105DB
https://www.ebay.co.uk/itm/334487476972?hash=item4de101daec:g:dH0AAOSwx~1iuuQZ
Front shock absorbers 1T0413031HK 1T0413031HP
(8) 1T0 413 031 HP gas shock absorber
for vehicles with sports suspension
  2 PR-G07+2UC+
L55,L58
(8) 1T0 413 031 HK gas shock absorber
for sports suspension
  2 PR-G07+2UC+
L59,L62
  2 PR-G07+2UA+
L58
https://skoda.7zap.com/en/cz/octavia/oct/2011-663/4/411-411030/
Bilstein B4 22-183729 front shock absorbers 1T0413031HK 1T0413031HP
https://www.autodoc.co.uk/bilstein/1043473
Bilstein B4 22-139191 front shock absorbers 1T0413031HP
https://www.autodoc.co.uk/bilstein/632158
Rear springs 1K0511115BQ 1K0511115BR 1K0511115BS 1K0511115BT 1K0511115CA 1K0511115CD 1K0511115CE 1K0511115DG 1K0511115DH 1K0511115GB 1K0511115GC
1 1K0 511 115 GB coil spring
1 paint mark
2 paint marks
rear
blue
brown
2 PR-1JC,1JS+
0YA
1 1K0 511 115 GC coil spring
1 paint mark
3 paint marks
rear
blue
brown
2 PR-1JC,1JS+
0YB
1 1K0 511 115 BQ coil spring
1 paint mark
rear
blue
2 PR-1JC,1JS+
0YC
(1) 1K0 511 115 BR coil spring
1 paint mark
1 paint mark
rear
blue
yellow
2 PR-1JC,1JS+
0YD
(1) 1K0 511 115 BS coil spring
1 paint mark
2 paint marks
rear
blue
yellow
2 PR-1JC,1JS+
0YE
(1) 1K0 511 115 BT coil spring
1 paint mark
3 paint marks
rear
blue
yellow
2 PR-1JC,1JS+
0YF
(1) 1K0 511 115 CA coil spring
1 paint mark
1 paint mark
rear
blue
orange
2 PR-1JC,1JS+
0YG
(1) 1K0 511 115 DG coil spring
1 paint mark
2 paint marks
1 paint mark
rear
blue
orange
brown
2 PR-1JC,1JS+
0YH
(1) 1K0 511 115 DH coil spring
1 paint mark
3 paint marks
1 paint mark
rear
blue
orange
brown
2 PR-1JC+0YJ
(1) 1K0 511 115 CD coil spring
1 paint mark
1 paint mark
blue
green
2 PR-1JC+0YK
(1) 1K0 511 115 CE coil spring
1 paint mark
2 paint marks
blue
green
2 PR-1JC+0YL
KYB RA7102 rear springs 1K0511115BR 1K0511115BS
https://www.ebay.co.uk/itm/234604719073?hash=item369f87ebe1:g:Zs8AAOSwGRliuuIb
Rear shock absorbers 1K0513029EP 1K0513029GP
7 1K0 513 029 EP gas shock absorber rear 2
(7) 1K0 513 029 GP gas shock absorber
rear 2 PR-1JS
https://skoda.7zap.com/en/cz/octavia/oct/2011-663/5/511-511020/#7
Bilstein B4 19-140025 rear shock absorbers 1K0513029GP
https://www.autodoc.co.uk/bilstein/638649
Edited by Carlston
Thanks for the responses folks. Those build codes sure make things more complicated. Bit more digging needed.
Works fine for me.
Use a proper computer not a phone and don't confuse zeros for the letter O.
Fair, I am on my phone at the minute. I'll try again later when I'm home.
