Gearbox manual issue on skoda vrs mk2 z5 facelift. ccza engine
Hello and good summer.
As for now I've drive skoda vrs mk2 facelift 1z5 ccza engine for almost 6 years now. I've been fitted the car nice over the years.
As for now i got problems  with my gearbox and not the clutch.  As now it starts to wear out in gear ratio somehow. Started to  make clugging noise. Been driven for 190.000 km now. Its on my 2nd clutch as it got ZF sachs performance clutch on it. And I tought it started to be  some problems with clutch, but it seemed to be the gearbox. Now im looking for options what kind of gearbox that might fix my car from an example Golf gti 6 or like that. Or I've to take out the gearbox and get it fixed.
As i try to find part number on the gearbox and its not easy to seach for manual/vin codes for the car as the websites is getting closed down i many ways. Anyone klnows which gearbox code its on this one? LHY or its HJH or others?
I will be very thankful for any helps. As I started to get hang on caravans trips and now yessss, I need to get this solved and open for tips for upgraded gearbox which can tolerate to tow heavy beef and the car has been chipped since i got it.
I wish you all a great summer :)
Have a look at the options sticker either in your service book or under the carpet in the boot.  That will tell you the engine type, gearbox, paint code and all the other options on the car.
In the above case the car is a 1.9tdi ambiente with a JCR gearbox, 9154 paint and a BXE engine.
You do not say what year your car is ? but for a 2011 1Z5 with CCZA the drive gearbox codes listed are:- KPV, LQZ, LTL, MMA, MSY, NJL, NLR & PBH all 02ED series gearboxes
If you want to physically check which gearbox is fitted look at the stamped code by the shifter lever.
Thanks a lot. It’s 2012 model.
Gotta start to check out gearboxes used, but they seem to be high mileage anyway. I got contact with one company. Only to open and diagnostics the gearbox is 300£ So it will be almost 1000£ price full I think.
Might just make bigger/stronger upgrade so it tolerate a little bit. As I search for the value of this car in Norwegian marked is almost holds the price 10.000£ And up for 190.000km.
changed a lot in this car.
New chain system and tensioner system from bartek tuning with stronger chain system etc. new turbo, racing cells 200 exhaust from turbo to mid from Ferrita, and original exhaust from mid to the end. Very beautiful sound :D not loud but little angry in higher rpm.
 It’s getting rare on these cars in benzin. All vrs got in diesel pretty boring and low prices and getting more restrict to drive in city’s etc.
I will update how’s going with this ^^
So far I've been in touch with 3 companies and they're all saying it will be atleast 2000£ or  more to get it fixed. So i gotta make some research and might try to buy all the syncro rings and stock rings idk whats called in english as in translate for english it says warehouse hahaha. Like a repair kit and fix it by myself :)
Any one has done overhauling on manual box for this? Will be great with tips :D And thank you for taking time to read the topics and comments :)
