Workshop manual for timing up the BLT vrs engine
Morning guys,
Does anyone have a pdf of the workshop manual for the fabia VRS, BLT if possible?
I need to time mine up from scratch, I've seen the guide for changing the belt but I need the workshop procedure if poss.
Not sure whether the BLT crank pulley markings changed, my usual pd tooling doesn't seem compatible.
I've tried a few link on the forum, some list the right model, when you open the pdfs though the pages are blank for some reason.
Thanks in advance
From memory there's a tiny triangle on the crank pulley which needs to be at the top pointing vertically before you fit the crank locking tool, I seem to remember using a 6 or 7 mm drill bit to lock the cam in the right position before loosening the two pulley bolts, once you've done these steps you can go ahead and fit the new belt before releasing the tensioner keeper.
It's pretty straightforward.
Thank you 👍
