Wing mirrors faulty?
Superb estate 2018 seems to have lost wing mirror function. If I manage to get nearside correct and release the toggle the mirror just goes back to where it was. If I try again I can get it to stay and then realise the offside mirror has now moved without any input from me? I am user 2 on the seat position but it only ever shows user 1 on the dash display.
Any advice is appreciated
Try moving the offside mirror first before the nearside. The manual will explain more.
No dice.....So I went into the system and chose user options. Set driver 2. The mirrors moved into position but not correct. How do I adjust from user settings to correct this misalignment? I cannot see this in the manual. Driver 1 settings are way way off.
Should be fairly simple to manually adjust these mirrors as no settings have been changed by us. Of course I can manually move the glass but for this mass of electronics is that the option to use?
I assume you have memory seats? In which case, I'd try setting the memory positions again...
From an Octavia manual but the Superb should be pretty similar if not identical.
From page 86:
And regarding memory per key:
