Who’s fitted Blistein B6 dampers to Vrs estate.
Hi,
I have done a bit of searching but can’t find what I am looking for.
Has anyone fitted Blistein B6 dampers to the rear of and Vrs diesel Estate 2017 without changing anything else.
Not interested in lowering or putting coil overs on
I am getting a bit of noise from dampers I believe and it’s getting a bit soggy on the arse end, often has quite a bit of weight in.
I am running 19” wheels so it’s a firm ride which ok.
I am told B4 is a direct OEM replacement and B6 supposed to be 20% firmer.
don’t want to turn it into a teeth chatter box.
Is it worth spending the extra £100 on a pair of B6s
Thoughts?
B4 are generally thought to be around 10% stiffer than the oe dampers. I have some in the garage still waiting to go on my car. Only been there 8 months now 🤣
If you've been carrying loads I'd measure the static height. I find the rear springs need replacing from about 5 years on.
