18” x 8.5” wheel for RS230?
Hi team
Anyone have experience of fitting a 18” x 8.5” +35 offset wheel to their RS230 using stock tyre size? (225/40/18).
willtheyfit.com tells me there will be 28.7mm more poke.
Hoping they will fit without rubbing. Car will be lowered a some point.
Is the car a facelift or pre facelift?
The facelift has a 38mm wider rear track and can just about manage 8.5j et45. . So et35 on a PFL should be fine.
225/40 on an 8.5j is probably on the limit or just over the limit of the manufacturers reccomendations depending on brand of tyres. .
Rubbing shouldn't be an issue unless you go really low ( on a PFL it might not be an issue at all)
I have a MY17 RS230 facelift. I thought the wider track was for RS245?
You may be correct. . . I'm not 100% sure myself
I have this which I found on here a while ago when I was doing some wheel calculations for my 245.
