New car key cut
Hi guys ive purchased a new car key for my sons car as it only had the one key with the fob integrated, the key came with a small glass item that fits in the key, the key opens the driver door great but obviously it dont start the car, is there a way that it can be programmed??
The small glass item is the RFID chip for the immobiliser, it can be copied, you can get a new one made at a decent locksmiths.
No sure what you mean its brand new, whats the options ?
I purchased the new key from ebay it unlocks all the doors perfectly but doesn't start the car,the rfid chip transponder is inserted within the key,do i need to program this now?
heres a website ive found is this correct >
https://www.programyourkeys.com/Program_Car_Keys_-_Skoda.html
That link is for pairing the new key to the central locking not the immobiliser chip, to do that you need to read the immobiliser PIN code from the speedo unit then with VCDS you can match that RFID chip to the immobiliser or Timpsons shoe menders might be able to just read the chip in the original key and copy it to the new one
ok thanks pal, the key opens the central locking already so will try simpsons
