Sachs 998 411 Front Springs
Hi all,
Bit of a long shot, anyone bought any Sachs front springs for a VRS with Sachs PN 998 412 from euro car parts?
Euros list 2 different Sachs shocks, just trying to work out which are the correct Sachs number as they don’t list the manufacturers PN.
Dan
2 hours ago, brown_d9 said:
Hi all,
Dan
Sachs 998 412 matches 1K0411105EB which isn't listed as an Octavia MK2 VRS front spring. However, the specification of 1K0411105EB is similar to 1K0411105DB. Sachs 993 053 matches 1K0411105DB.
On autodoc, Sachs list the 1K0411105DA for the petrol VRS with manual gearbox.
On autodoc, Sachs list the 1K0411105DB for the diesel VRS with manual gearbox and petrol VRS with automatic gearbox.
On autodoc, Sachs list the 1K0411105DC for the diesel VRS with automatic gearbox.
However, it's always worth checking the car's build codes to find out what front springs the car actually left the factory with as this could be different from what Sachs or any other aftermarket spring brand recommends.
Octavia MK2 VRS front springs
1 1K0411105DA Coil spring
3 paint marks
1 paint mark
red
Grey
2 PR-L55
1 1K0411105DB Coil spring
1 paint mark
1 paint mark
1 paint mark
red
white
violet
2 PR-L58
1 1K0411105DC Coil spring
1 paint mark
1 paint mark
red
violet
2 PR-L59
1 1K0411105DD Coil spring
1 paint mark
2 paint marks
red
violet
2 PR-L62
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/4/411/411030
Edited by Carlston
Thanks for replying, on the actual Sachs online catalogue it lists the Sachs 998 411 (not 412 as I put previously, my bad) with the correct paint markings.
Just trying to work out which one is the right one on Eurocarparts. Going to end up paying massively over the odds with them but the supplier on eBay I had some on order with for half the money has now told me they are out of stock / can’t get any more !
According to autodoc, Sachs 998 411 matches 1K0411105DA.
https://www.autodoc.co.uk/sachs/1234231
Sachs 998411 is listed on amazon for £33.30 including shipping. Delivery is claimed to be by next Friday
https://www.amazon.co.uk/Sachs-998-411-suspension-spring/dp/B00DZA6HFO/ref=sr_1_1?crid=38FHMS2W2FBR0&keywords=sachs+998411&qid=1663237400&sprefix=sachs+998411%2Caps%2C68&sr=8-1
eurocarparts are showing that "Sachs Coil Spring (Front) Product Code: 627447560" matches build code L58 and is therefore a 1K0411105DB front spring
https://www.eurocarparts.com/p/sachs-coil-spring-627447560
eurocarparts are showing that "Sachs Coil Spring (Front) Product Code: 627780520" matches build code L58 and is therefore a 1K0411105DB front spring
https://www.eurocarparts.com/p/sachs-coil-spring-627780520
eurocarparts are showing that "Sachs Coil Spring (Front) Product Code: 627444130" matches build code L59 and is therefore a 1K0411105DC front spring
https://www.eurocarparts.com/p/sachs-coil-spring-627444130
eurocarparts are showing that "Sachs Coil Spring (Front) Product Code: 627790480" matches build code L59 and is therefore a 1K0411105DC front spring
https://www.eurocarparts.com/p/sachs-coil-spring-627790480
However, eurocarparts are showing that both Product Code: 627447560 and Product Code: 627780520 match build code L58. Unless these Product Codes are for the identical Sachs front springs that match build code L58, then eurocarparts would appear to have made a mistake.
Also, eurocarparts are showing that both Product Code: 62744130 and Product Code: 627790480 match build code L59. Unless these Product Codes are for the identical Sachs front springs that match build code L59, then eurocarparts would appear to have made another mistake.
On eurocarparts, to see the listings of the Sachs springs that show the L58 and L59 build codes it appears that you have to select the Octavia MK2 2.0 diesel. eurocarparts product codes 627447560 and 627780520 are listed against both the Octavia MK2 2.0 petrol and Octavia MK2 2.0 diesel cars, whereas all the above four product codes are listed against the Octavia MK2 2.0 diesel cars.
It appears that eurocarparts don't list Sachs 998411 that matches 1K0411105DA.
Edited by Carlston
Sachs 998411 matches 1K0411105DA (for Octavia MK2 petrol VRS with manual gearbox)
  • Length [mm]:315
  • Diameter [mm]:137
  • Number of coils:5.25
  • Weight [kg]:1.75
  • Wire Diameter [mm]:12.25
Sachs 993053 matches 1K0411105DB (for Octavia MK2 petrol VRS with automatic gearbox and Octavia MK2 diesel VRS with manual gearbox)
  • Length [mm]:307
  • Diameter [mm]:146
  • Weight [kg]:2.15
  • Wire Diameter [mm]:13.00
https://www.autodoc.co.uk/sachs/7070584
Sachs 997857 matches 1K0411105DC (for Octavia MK2 diesel VRS with automatic gearbox)
  • Length [mm]:315
  • Diameter [mm]:148
  • Weight [kg]:2.15
https://www.autodoc.co.uk/sachs/1233677
Edited by Carlston
im hijacking this for a related question...
arb bushes...
how do i know whcich part number i need for front and rear?? without climbing underneath and searching.. theres at least 3 options on each end!
cayc 1.6cr saloon...
Edited by mac11irl
arb bushes...
how do i know which part number i need for front and rear?? without climbing underneath and searching.. theres at least 3 options on each end!
Which anti roll bars are fitted depends on the car's build codes. Have a look at the list of your car's build codes for any of these: 0AC 0AD 0AE 0BC 0BH 0BD 0BJ 0BE 0BK 0BF 0BL
Front anti roll bar (front wheel drive)
16 1K0411303BH stabilizer, complete
marked with:
21,7X3
orange
1 PR-0AC
16 1K0411303BJ stabilizer, complete
marked with:
22,5X3,5
blue
1 PR-0AD
16 1K0411303BK stabilizer, complete
marked with:
23,6X3,5
green
1 PR-0AE
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/663/4/411/411000
Rear anti roll bar (front wheel drive)
16 1K0511409BA Anti-roll bar 18,5X2,5 1 PR-0BC,0BH
16 1K0511409BN Anti-roll bar 18,5X2,5 1 PR-0BC,0BH
16 1K0511409BP Anti-roll bar 19,6X2,6 1 PR-0BD,0BJ
16 1K0511409CA Anti-roll bar 20,7X2,8 1 PR-0BE,0BK
16 1K0511409BC Anti-roll bar 21,7X3 1 PR-0BF,0BL
16 1K0511409CB Anti-roll bar 21,7X3 1 PR-0BF,0BL
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/663/5/501/501020
VW Codes Decoder
0AC = Front stabilizer
0AD = Front stabilizer
0AE = Front stabilizer
0BC = Rear stabilizer
0BH = Rear stabilizer
0BD = Rear stabilizer
0BJ = Rear stabilizer
0BE = Rear stabilizer
0BK = Rear stabilizer
0BF = Rear stabilizer
0BL = Rear stabilizer
http://igorweb.org/equidec.aspx
Edited by Carlston
thanks @Carlston
appreciate that little nugget, will have a look in the morning
okay, i cant see any of those codes on the build sticker...
so, ill have to go underneath later or tomorrow and see if i can see any markings or part numbers
The build sticker only has a small selection of the build codes, perhaps around 40.
The car might have around 180 build codes.
You can get all your build codes for about 3 Euros on ebay. Search "skoda vin options" on ebay to find the listing.
fyi for anyone else looking,
turn your steering on a full left hand lock, and on the passenger side clean the dirt off the end of the front ARB.
the colour dot marking can be seen there to identify which one you have.
im on a blue, thus the front bushes are a BJ suffix.
jacked up a back wheel to try the same on the rear arb, but couldnt seen enough to find a part number sticker or marking on it, so will need to get the axle stands under it and try again.
i was at work on my lunch having the first look so not enough tine or gear to go under looking..
I spoke to eurocarparts and asked which of your product codes matches Sachs number 998 411, they read it out and indeed confirmed that none of the numbers listed on their website were correct in this instance.
Scary really, just goes to show you cant trust one of the biggest suppliers of parts own website!
