Fabia 2012 1.2 wiper & window problems.
Hi guys back with more problems unfortunately.
I don't know if thesee faults are related in anyway.
1st the drivers door window has started to only work intermitantly I know it isn't the wiring as this was checked repaired not long ago & a different motor fitted (Thanks Pete :) )
2nd yesterday I went to use my front wipers and nothing happened which was unfortunate as I was driving and had just sprayed the screen.
The screen wash is working (obviously) and the rear wiper is working.
I have checked the fuse and that is fine.
Does any one have any suggestions as to what could be causing the problems & how to repair them myself cheaply.
Cheers Jim
Not sure why you are so sure the window is not related to wiring problems, if this has been repaired prior it should be the first port of call imo.
Wipers are likely to be the stalk itself "imo", Im assuming they do not work on any speed ?
No the wipers are completely dead at any speed
I am assuming you have checked both fuses relevant to the wipers.....?
Fuse 44 - 20AMP
Fuse 10 - 15AMP
Fuse 44 - 20AMP
Fuse 10 - 15AMP
Hi
No I checked 26 & 44 front & rear wipers
What is fuse 10 for?
26 is rear motor,
44 is front motor
Fuse 10 provides a feed into the wiper stalk / switch, not saying it's the issue, but certainly worth checking.
3 minutes ago, UrbanPanzer said:
26 is rear motor,
44 is front motor
Thanks for the info I will check it asap
Fuse 10 is fine the rear wiper & screen wash are working fine so power is getting through to ther stalk.
Thanks for the suggestion :)
Finally got the fault repaired turned out the wiper motor had seized.
Removed motor plenty of WD40 and working again.
Decided though to get rid of the car.
