Alarm motion sensors
Is it possible to alarm the Kamiq without the motion detector so that a dog can be left in it?
Hi, welcome to the forum. Possibly - does your vehicle have a switch near the bottom of the B pillar on drivers side?
Edited by Warrior193
Add welcome
Best check your owners manual. As above there could be a switch on the drivers b pillar, there could be an option in the vehicle screen to disable, or as per most other models pressing the remote lock button twice turns off the interior monitoring, but note it also turns off the deadlock.
From the online owners manual:
Quote
The following functions of the alarm system can be deactivated at the same time:
  • Interior monitoring
  • Towing protection
Deactivation will also switch off the SAFE function  Central locking.
Deactivation
  • By double locking within 2 seconds.
Or:
  • In infotainment in the menu 656963703_ScreenShot2022-10-23at3_47_29pm.png.fa462aaa40e6b5cf3e45a0ca69037d9e.png Menu item for interior monitoring
Or:
  • In infotainment in the menu 1246113705_ScreenShot2022-10-23at3_47_51pm.png.5dd87b8ac11202989cc7ed1db374b7aa.png Menu item for interior monitoring
The deactivated functions are reactivated after the vehicle is unlocked and locked again.
604626017_ScreenShot2022-10-23at3_48_11pm.png.f9195d8804da03b6f957b60028f9da0b.pngDeactivation is to be carried out if the vehicle is, for example, towed or transported.
You can also add a shortcut button to the pull down menu in the infotainment.
Next time post this in the main Kamiq chat not the Guides section.
