Correct engine oil for 1.9 td diesel 08 plate
Hi
Is 5w-40 the only oil i can use or can i use 5w-30? last time i used Shell helix 5w-40 hx8 ?
many thanks
Which ever viscosity of oil you choose, make sure it's either 505.01 or 507 rated, otherwise you will end up with camshaft problems.
ok great thank you.
See the sticky in this forum.
Have been using Quantum Platinum for years now and never looked back.
Thankyou
I looked on the leftover shell helix oil container and couldn't see any of the figures you stated
  • Sponsor
So for the next change pick one where you can see one or both. May be written 505.01, 507.00, or with spaces instead of the dots. 505 01, 507 00.
Nothing else matters.
Great thanks .shame oil has got expensive now!!
Thankyou for the information.i will check it out .
