Clutch In Octavia 1.9 Tdi
I'm a car mechanic and I have an odd problem with clutch in Octavia 1.9 TDI (milage: 150 000 km). At first it was typical - problem with used clutch plate. After swap of complete set (LUK): when you press clutch pedal until the end release lever wipes pressure plate. I have also change clutch release slave cylinder. It seems to be all right but after two days problem come back. It is impossible to change gears. Has anybody come across this kind of problem? And, of course can help me somehow? Thanks in advance.
I had a similar problem and it was the clutch master cylinder. Common on VAG.
