Battery sensor wire routing?
  • Sponsor
I'll look up where that pin 3 supply is coming from in a sec, just need to finish making a cuppa.
  • Sponsor
I'm confused by that, pin 3 seems to go to the right dipped beam headlight bulb, so shouldn't connect to batt positive?
What range is that meter on, in the pic where you're on pin 6, and is the probe definitely getting in there properly, and where's t'other probe?
  • Sponsor
If it was me, I'd run in a new wire from the cut stub of the one coming out of pin 6, all the way to near the fuse and splice into the existing wire there too.
Ok, all faults now clear down after running live feed to pin 6 so it is a break in the engine bay somewhere!
Just need to find somewhere neat to tie this in to now……
  • Sponsor
Can't you just run that wire along the existing loom, out through/near the grommet that takes the loom out of the scuttle into the bay near the ECU, and splice into the fuse wire after following the loom from there? May be hard to do super-neatly, but I'm not that fussy. 😁
Great work guys! :thumbup:
