Yellow oil light
Hi guys... anyone know why the yellow oil light would stay showing on the dash???.. ive tried the bonnet open bonnet close procedure but that didn't reset it ?? The oil level is fine so I'm a bit confused?? Cheers
Theres a sensor at the bottom of the sump. Have a look at that. The wiring plug had corroded on mine, had to replace the sensor and connector.
We found the issue... it was a faulty bonnet switch. Thank you tho 👍
