The Games Manufacturers Play
Tripped over an Auto Express article on the latest Enyaq VRS Coupe.
Shocking tricks being played with real world performance some way behind the brochure headlines.
So is it 10 seconds as published above, or 30 seconds as spoken below in the first vid as read from something else that was published?
Best not get one then if you want to be taking it to the 1/4 mile strip or doing lots of traffic light grand pr1-ck starts.
Still nippy though even if not putting out 100% of the linear power / torque.
**Once you have got something off your tail and you are zooming along at 112 mph it will likely keep doing that even if only putting out 245 bhp because the battery has been used up and only has 20% left or even less.**
Edited by toot
Same thing applies for every single vehicle, no matter if it's bev or ice. I've never heard of a flat line torque -hp graph. It's always a curve. Sure it's not in time, it's on rpm, but when accelerating you can't keep rpm steady. So it's almost the same.
  • 3 years later...
**Once you have got something off your tail and you are zooming along at 112 mph it will likely keep doing that even Adopt Me script if only putting out 245 bhp because the battery has been used up and only has 20% left or even less.**
Which vid as read from something else that was published?
^^^ 4 years later.
@Evolution13 that's a spammer, see link inserted into quoted text.
Reported.
