Extended Warranty
I am not sure if this is the right area for my enquiry but as I have a 2014 Yeti I thought to try here. Apologies if it is not.
I have had an extended warranty with Skoda for a few years now (dread the thought of replacing the DSG) but now wonder if there are better options through other organisations. Do you have some advice/recommendation?
Hello David, at the age of your vehicle, I doubt that any warranty provider will be able to supply a reasonably priced policy that will be able to cover your concerns.
Given the likely exclusions in any policy T&Cs, I feel you may be better to save any premiums you would pay against the day you need it for repairs.
How many miles has it done?
Probably best stick with them as long as you can get covered,
that is If the DSG is covered, so the clutches & MCU & you are having it serviced when due,
and if not covered and a wet clutch DSG then just be sure to keep getting it serviced correctly when due.
http://insurewithskoda.co.uk/extended-warranty
