No heating
On 06/02/2023 at 02:01, coley8978 said:
I have had it scanned and their is no codes
With VCDS  ??
  • Replies 63
  • Views 10.4k
  • OTOH, the weaker you make it, the more likely it is to freeze, and if you're lucky you push out one or more core plugs: If you're not lucky you crack the block and.or head.
  • KeithCheetham
    KeithCheetham
    Time to take to someone who can actually route cause the issue rather than keep guessing or throwing parts at it, You never answered my question on what distances you drive and over what type of terra
  • I read it as Pete did, I think its lacking a comma (after thermostat) as to my knowledge there is no such thing as a "thermostat expansion bottle"
Yes it's got manual controls why would it show up manuals controls where would the electrical  bits be?????????
It's a skoda fabia 2010 1.6tdi manual box manual heater controls
Was this age of Fabia ever fitted with the "mit silikat" header tank where the silikat "bag" has been bursting and blocking the fine core of the heater matrix?
On 28/01/2023 at 10:17, coley8978 said:
So far I have changed the water pump and belts
Changed thermostats 3 times
Changed the expansion  bottle and cap
Changed the main radiator
Changed the heater matrix
Still no heat from heater blower only almost warm air
How do I find the heater blender or flaps
My system is electronically help help
 Time to take to someone who can actually route cause the issue rather than keep guessing or throwing parts at it, You never answered my question on what distances you drive and over what type of terrain - changing a thermostat 3 time suggests that it is still not getting up to temperature, changing a radiator would generally be due to overheating rather that running cool, you have not confirmed if you have tried an extended drive on the motorway, there has been no clarification of the available engine temperature now you have changed all the above items - still 68C? which is an odd value as a stuck open thermostat would cause temp to rise and fall and not stabilised unless the water temperature sensor is an issue. To change the heater matrix did you not have to remove all the heater mixer controls?. Also details of actual model may have assisted in allowing people to identify heater system - S, Se or Elegance - as the engine was available in different trims.
After reading the horror stories on here (and elsewhere) about silica bags bursting in the coolant, I was delighted to find that my Fabia does not have one.
Has anybody ever fixed a turbo actuatior              on a skoda fabia 1.6 tdi with intercooler
Can the turbo actuatior  be fixed without removing the turbo
I doubt it, but I'd be able to tell if I opened the bonnet, removed the engine cover and used a torch and my eyeses...
That's so funny
Well I can tell you it can
If you can't help keep it shut
I did help and my opinion of your abilities is increasing slightly, mind you it was starting from a low base!
A new actuator needs adapting after fitting.
and there was me thinking this topic was a continuation of the heating problem.............:thinking:
Edited by UrbanPanzer
 I assume that this question is now answered.
