Superb Mk2 Window Regulator Replacement
Seasonal greetings to all,
Have a problem with my superb my drivers side front window tried to open against the frost, and failed by snapping the cable and winding it around the drum, but I can't figure out how to remove the old one.
Have done a search of the site and it seems the guide to use for replacement is via a link -
https://nackuk.blogspot.com.au/2011/09/repair-skoda-superb-window.html
But the link seems to be gone.
Can anyone give me some advice, or have a copy of the guide from nackuk ?
Many thanks in advance.
First thing is to detach the glass from the mechanism - pop out the rubber bungs and drop the window until you can see the plastic pins that hold it and push them through. You can recover them from inside the door later. Pull the glass up and tape it over the top of the door to keep it out of the way.
Then remove the 6 screws holding the metal plate with the regulator in place. Wiggle it around until you get it lined up to pull out of the door. Pop off cables as needed.
You have to swap some parts over but that's fairly obvious if you put the old and new ones side by side.
Many thanks for the quick reply.
Hi @TeamTaylor, how did you get on with this fix? I ask as I'm 99% sure I have the same issue on the same door and in the same circumstances (tried to use the window in the recent frost/ice) and I think I'd wrecked the regulator too. Thanks in advance
  • 2 years later...
hi all whats the best way to remove those plastic pins?
