Drive Modes Memory (or lack of)
As per title really......
My 2016 L&K 2.0tdi DSG remembered the drive mode it was last in (individual) upon its next start..................the 2019 model I got today doesn't, the only difference is this new one is a 150 the 2016 was a 190.
Is there any solution to this????
It's an emissions thing. It resets the mode to least (ish) emitting setting.
Mine's the same, always reverts back to 'Normal' on start up.
The annoying thing is if you have it in sports for example and get out and lock it up. When you come back to the car the mood lighting etc is still on sports until you start the ignition, where it then defaults back to normal.
So it clearly remembers the last-used mode and then resets. I'd have thought someone would have found a coding workaround by now
It's part of the CAN gateway dataset.
Not something that can be changed with VCDS or OBDeleven. You'll need to create a custom dataset and use ODIS or VCP to update it.
That's not gonna happen anutime soon .........I'll just have to get used to pressing the mode button 3 times after each start.
I'll be exhausted!!!!🙄
