Fog light removal Super facelift
Hi guys, I would like to remove my fog lights to check their condition considering I have some condensation. Does anyone know how to remove the plastic grille?
  • 9 months later...
Hi there, did you manage to remove the light? If so, how did you do it?
Hi. did you succeed or find how to remove the fog light? I have the same problem with a 2021 SS3. can you help me too. thank you
I could be wrong but isn't there a little trim removal tool with the spare wheel, a loop on one end for your finger and a hook on the other to go through that little hole in the grille under the fog light  and help you pull the black grille off ?
That should let you get to the mounting screws of the fog light.
OK. I will try your version. but when it warms up. that in the winter the plastic becomes brittle and I'm afraid to try not to break the plastic.
They’re all LED so expected and normal behaviour I would have thought?
Just like the DRLs
  • 3 months later...
any luck removing the foglight yet? I have the same condensation issue ans would like to get the foglight out to look where the problem is.
Removing the whole bumper would be too much trouble
On 29/11/2023 at 16:45, lway said:
I haven't tried, but it sounds reasonable to try the procedure that Iway posted. I remember I have the tool for removing the trim in my spare wheel compartment..
  • 2 months later...
Today my garage replaced the foglight under warrenty. They had to remove the front bumper to get the light out.
