Columbus Infotainment System
Following a flat battery over Xmas and replacing with a brand new battery, my system is displaying the following message - Software Download-Source activated, searching for SWL Image.
Can't knock it off and back on so have had to resort to disconnecting it as its draining the new battery. Skoda main dealer has looked at it and told me that the head unit has gone. Is it repairable or any advice on the best places to replace it please?
  • Replies 53
  • Views 19.9k
  • It's looking for CD with SW upgrade. Take the unit out and post a picture of upper case label.
  • Cannot believe the dealers just condemn unit 😤 easy money for them.
  • Me or Pab567 would be able to send.  They are on eBay if you cannot burn CD-R.   As for the pressing, not sure yet as the firmware recovery might actually allow some functionality to work, a
Thanks for response. I will have to do it in the morning.
Yes, I thought the same. Hoping that I can get some better advice on here.
As long as you can burn a CD-R from an ISO image, you will be ok.
This will give you an idea of what you will be doing
Thanks for that. Main problem that I have is that none of the buttons work and everything seems to be frozen. Don't know if putting in a CD would change this though? Where would I get the update discs from please?
As for the pressing, not sure yet as the firmware recovery might actually allow some functionality to work, as it's in recovery mode.
Take a picture as requested, and fingers crossed.
Photos of the top, side and the message on the screen
I've answered this before, me or @pab567 are able to send you the file you will need to burn to a CD-R disk yourself.
Can you/someone you know burn a CD?
It's not "frozen" it's waiting to be fed with a firmware CD, and then it will take over the boot code and the buttons should work.
Ok, you have this value on your image 3T0035686C, which you can see in the following and the firmware matches with 5238
RNS510 SW5238
#Integrationphase: Delivery cw45/12 C10/C12/C6-samples
#VwSwPartNumber:1T0035680L/3T0035680G/7F0035680B
#/7E0035680B/1T0035680P/1T0035680Q/3T0035680K/3T0035680L/1T0035686/1T0035686C/1T0035686D/7F0035686/7E0035686/3T0035686/3T0035686C/3T0035686D/7N5035686/2H0035680
#VwSwIndex:5238/5238/5238/5238/5238
#AppsBuild:C_EU_13.236_t3 C10/C12/C6
There is an update available to increase your version (recommended) to 5270 version
RNS510 SW5270
#Integrationphase: Delivery cw45/12 C10/C12-samples
#VwSwIndex:5270/5270/5270/5270/5270
#AppsBuild:C_EU_13.270_t2 C3/C4A/C5C/C6/C10/C12
As just mentioned, this can be sent as an ISO file, and you just need recording software (Windows itself can do it) to burn this to a blank CD-R
Additional information in text, similar to above video.
https://paulroberts69.wordpress.com/2015/10/01/upgrading-firmware-and-maps-on-vw-rns-510-satnav/
Edited by varooom
I am not too Tec savvy but am able to burn a CD off  my laptop.
Grab your blank CD, I will send you a link
Do you want to send to my email address as I don't have one to hand? Apologies I am on granddaughter duty at the moment.
I have sent you a forum private message, link is in message top right.
email address are not allowed, and forum will blank them out, for your own safety ;)
I suggest to use 5274, not 5270, as 5270 (as well as 5269) are kind of buggy
Can you PM him a link please to 5274 so he has this?
Edit: I do have 5274, if not in your hand.
5274 as suggested by @pab567 :beer:
S00.1000.03.99
#VwSwIndex:5274/5274/5274/5274/5274
#AppsBuild:C_EU_13.274_t2 C10/C12
Edited by varooom
Additional Information
Sent :)
Sorry to jump on this post. My columbus is occasionally shutting down then restarting I am told it make need this update disk.
Would one of you kind gents be able to email me something?
Below or attached is what the car says I have
@BigAndyGreen
Nobody can email you the file, but can you burn a CD?
Yes i can
5 minutes ago, BigAndyGreen said:
Yes i can
I will send you a PM in a moment then.
Hi Andy,
varoom resolved my issues and saved me a fortune. Highly recommend his advice and guidance.
Apologies to @BryRod
 also asking, as I have similar problems if I may PM you good gents for the corect upgrade version number please? Here is my removed unit. Thanks
