Ambient lighting
Hey all can anyone please help. My mate plugged OBDeleven in to adjust my headlight washers but he’s also messed my ambient lighting up. If I pick white it shows on the radio and speedo as white but the strip in the doors is red.
Never mind i came across a post on here that a user used a script on there superb 3. @Ivan8192 posted.
It worked great!
Edited by mattft86
@mattft86Can you give us more details? Or the link to that post?
It was in the surperb forum you download vcds scrip then run the script. I have the tool and scrip if you want it.
Yes, sure.
@mattft86 Hi, does the script also work on mib 3? How many colors does it have? Please send me the link. Thank you.
I can't say for sure if it will work with the mib3 I can't see Why not? You would need to find out for sure before risking it
I am about to upgrade the ambient lighting to the 2021 mib3, hopefully it will be wired to the BCM just like it was before the fl version.
Pin 1 > +12V (terminal 30)
Pin 2 > LIN (BCM Plug C Pin 29)
Pin 4 > Ground
Do you have a link to that script?
