Fuse 24
Hi there
So basically my 2018 Skoda Gabia estate cabin fuse box ain't the same as the diagram in the manual.
Apart from the fuse layout being  a very different the one I wanted to check (24 blower heater) isn't in it. I appreciate one of the fuses must be the relevant one. But which one.  Is this a well known issue.....hope so?
😊 thanks .
In July 2018 there was a change in the wiring diagrams, so yours will be either before July or after, and we had this the other day where someone's manual in the car didn't match reality.
Do you have a picture of your fuse board please, so I can compare workshop manuals?
I have looked through several manufacturer years (MY) from 2014-2020 and cannot see any changes from F24 a Green 30 Amp fuse is still assigned as Fresh air blower switch -E9-, Fresh air blower -V2-, Fresh air blower control unit -J126-
So it should be 2nd row, 2nd fuse from the Left to Right direction
Hi thanks for reply.
My Skoda was registered in March 2018.
The diagram you have kindly posted is the one that's nothing like mine (no 24 either)
I will try and send the pic of mine tomorrow.  Can't work out how to post a photo on here at the moment.
Have the photo saved, and then press choose files
Then you should be able to attach/insert picture
Example here
Fuse 24 is in right place... Green and 30 Amp
Please note - I am not a mechanic or expert in anything.
Has been know for Dealerships to shuffle round such things as Owner's Manuals, they had to take one out of another car when I insisted on a paper printed copy for my wife's car.
Try putting your VIN in the following link and see which version it gives you and if it ties up with the printed paper one you have, the version is printed on the last page(s) something like "Fabia anglicky 11.2017". - https://manual.skoda-auto.com/004/en-com/Models
My wife's Owner's Manual had it's title as "Operating Instructions".
Edited by nta16
missing words
