Towbar fitting advice
Has anyone fitted one of these towbars to their MK3 Estate and successfully wired up using the wiring kit supplied?
Much appreciate any advice as I think maybe I can handle the fitting but the programming scares me a little.
You need to show details of or a photograph of the kit, without that nobody has any way of knowing what the wiring kit consists of, whether it is a low impedance triggering relay, a supposedly universal canbus interface or an OE towing module with plug in looms.
Fair point and here is what I have in the box. it includes the 7 pin socket etc. Does this clarify?
Many thanks
That looks like an OE module & wiring harness that will require coding and also adding to the installation list (of modules), I'm afraid I can't help you any more on that but others hopefully will.
I think (others may confirm) that if your vehicle had the towbar preparation at the factory then there should be a socket for it or the loom to plug straight into.
Thanks - I have no towbar preparation so will be wiring it all in. No one seems to have done this kit so far so I may be on my own.
