RNS-510 columbus restart
Have encountered the skoda restart issue. My columbus unit is hw 23 sw 6270.
I have replaced the ssd using the  steps from https://www.vwwatercooled.com.au/forums/f78/rns-510-hdd-replacement-ssd-swap-diy-60984.html
i am now stuck trying to put the firmware on it. The latest firmware being 6276
The dvd locked on it with a cd in and I took apart the dvd and put in the new firmware disc ensuring the dvd was in the locked/home position.
When I turn on the unit and boot into the setup screen (setup,eject and mic) I get the insert swl cd Error
I am left wondering
1. Is the firmware i have correct? Can anyone provide a link
2. Is the dvd drive busted ...... if so is there any other way to get firmware on or would anyone have an image taken of their harddrive that I could download.
Any help would be greatly appreciated
Welcome, I can send you a firmware you are happy to try if your firmware disk is no good.
I can PM you a link and you will need to burn it.
Have you burn new firmware onto CD or DVD?
I burnt it on to a rewritable CD. Will try a CD R and see if i have any more luck.
Tried with a cd-r and the 6276 version from @varooom but still getting the insert swl cd error. So it must be down to the dvd-m5 position not being correct. I will go back to this a try again
