My twiddly bit has popped out my thingama-jig
My direction control twiddly bit now just spins freely. Looks like the little rod thing that it connects to has popped out either the control end, or the end in the venting system. Guess I'll have to whip out the control box which is easy enough. Just hoping nothing has snapped at either end, else it could be a bodge-it job.
Annoyingly it popped out when it was pointed at my feet. :rolleyes:
:thumbup:
I thought you were supposed to go to a gynacologist for thingama-jig issues? :rofl:
Get a whatsitsname and push the thingamyjig back in
sounds painful. :(
Ooh no, don't do that, you might twist the wotsit :eek:
ooooh, twisted wotsits! AGONY! :( I won't be able to sit down for days. :rofl:
Well just pop it back on with an oojamaflip then.
Sounds a slightly better idea, but make sure you use Oojamaflip model 5.2, the 5.1 can go off at a tangent if you're not careful !
The less tangents gone off the better when in that neck of the woods. Might put a nick in something I'd rather not. :eek:
Putting a nick in ones doodah is not recommended!:eek:
Look mate, I have no idea where your doodad is going, what your doobree is doing or how your flapstan is flopping.
Now if it was an issue with your togglespracket decraminator being U/S then I might be able to shed some light on its defribrilation and find a solution to your predicament.
I am sure however that someone more knowledgable will be along shortly to advise you in more detail on how to regain control of your knobby bit...
I'll get my coat :D :D :D
Nothing worse than twiddlering with your **** and breaking it!
