Possible clutch issue
Same here. Never got past the first stage. Beginning to regret buying the VCDS,  not much use without suitable instructions. Even Ross Tech mention UDS is sh1te.
2 hours ago, Aakayamy said:
First part of video I did but when I click on basic settings of transmission pops up saying Aborted straight away.
One of the pre-requisites for basic settings is g510 reporting between 30 and 60c. G510 is transmission temp I believe. Did you check what you could find for transmission temp? Pre uds they were in measuring blocks but now advanced measuring value or something like that and search text for transmission temperature ..
Have a read through this, it may help with pre-requisites.
http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_(DSG/0AM)
Edited by TheClient
The pre-requisites are easy enough to find, even with the UDS. The wiki page you kindly linked to unfortunately is CAN based and the steps listed cannot be followed.
I would be very surprised if there is not a very similar pre requisite list including temps. Do you want to share? Did you meet them? You can contact Ross Tech if you're the original cable purchaser.
Reply post 4#
https://forums.ross-tech.com/index.php?threads/18874/
Edited by TheClient
Hi guys quick update on this issue.
Finally got the car sorted. Dropped car off to a GEARBOX SPECIALIST in Glasgow on Monday and had new clutch packs and DMF replaced.  Cost me £2100 in total for repairs.
Car drives just like new and gear changes are much better as well.
Specialist did show me the old DMF and said it was needing replaced as it had too much play on it.
