Superb III Combi 4x4 Sportline
Hi,
I have a 2017 Superb III combi 4x4 sportline.  It' s a brilliant car but has very little ground clearance for the mountains that I live in (snow banks, gravel tracks etc) so I'm interested in finding ways to achieve more ground clearance through suspension changes and changing from the big 19 wheels to something smaller but with a more substantial tyre sidewall height.
Could anyone give me some advice on whether or not I could replace the suspension components with those from the newer Superb scout or another higher-riding skoda or if there are aftermarket options.
Thanks for any help.
On 10/05/2023 at 18:21, Naoise1 said:
Hi,
What engine do you have?
215/65R16 instead of 215/60R16 would gain about 10.75mm in ground clearance, and could be fitted to the standard 6.5Jx16 ET41 rims.
215/65R16 is a tyre size that has good availability of AT (All Terrain) tyres, such as the Yokohama G015 Geolander AT.
The Yokohama G015 Geolander AT has the 3PMSF symbol, so as well as being an AT (All-Terrain) tyre is also an all-season tyre, ie. it's winter rated, and has passed a test for good traction in the snow.
Yokohama G015 Geolander AT 215/65R16 98H (3PMSF symbol, so as well as being an AT tyre it's also an all-season tyre)
https://www.camskill.co.uk/m62b0s426p148189/Yokohama_Tyres_Car_Yokohama_G015_Geolander_AT_Yokohama_G_015_-_215_65_R16_98H_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_70dB
Yokohama G015 Geolander AT tyre
https://www.yokohama.eu/en/tyres/pcr-tyres/suv-off-road/?tx_tyre_pi1[action]=details&tx_tyre_pi1[controller]=Tyre&tx_tyre_pi1[diameter]=&tx_tyre_pi1[index]=&tx_tyre_pi1[name-select]=G015&tx_tyre_pi1[ratio]=&tx_tyre_pi1[speed]=&tx_tyre_pi1[width]=&cHash=51f8445d0b9edd39d6b8431ff82375cd
Edited by Carlston
Thanks @Carlston
It's a 2.0 TD1 DSG 190hp 4x4.  The tyres I have now are 235/40 R19
so I'll have to get new rims but was thinkthinking of some 17s.
Those tyres look like a good balance of on and off road.
I haven't got much room within the arch on my current tyres/rims so may have to add a spacer or something ?
12 hours ago, Naoise1 said:
Thanks @Carlston
If you change to 215/60R17, there will be more room in the wheelarches (at least horizontally) compared to 235/40R19 as they are about 20mm narrower.
There's plenty of owners who run 245/40R19 on their Superb MK3 without rubbing.
215/60R17 only adds 5.6mm to the radius of the tyre compared to 245/40R19.
A 6.5Jx17 ET38 5/112 57.1 steel rim from the Kodiaq could be used with a 215/60R17 tyre on the Superb MK3.
Yokohama Geolandar AT G015 215/60R17 96H
https://www.123pneus.fr/rshop/Pneus/Yokohama/Geolandar-A_T-_G015_/215-60-R17-96H--RPB/R-358069
Alcar 9021 6.5Jx17 ET38 5/112 57.1 steel rim (from Kodiaq)
https://www.123pneus.fr/rims/details?vehicleId=672860434273997936&rimCode=ALCAR9021
The Kilen and Lesjofors spring catalogue lists 5Q0411105GN front springs and 3Q0511115M rear springs for the standard ride height Superb MK3 estate 2.0TDI 190HP 4x4.
Changing from sports springs to standard ride height springs would increase the ride height by about 15mm.
Another option, is to fit increased ride height springs. This would increase the ride height by about 30mm compared to sports springs.
So a change of tyres to perhaps 215/60R17 and a change from sports springs to increased ride height springs would increase the ride height by about 40mm.
Various aftermarket increased ride height rear springs are available that are sold to replace OEM part numbers 3Q0511115AS, 3Q0511115AT, 3Q0511115BA, and 3Q0511115BB.
Increased ride height rear springs for the Superb MK3
1 3Q0511115BG Coil spring   2 PR-UC7+0YA
1 3Q0511115AN Coil spring   2 PR-UC7+0YB
1 3Q0511115AP Coil spring   2 PR-UC7+0YC
1 3Q0511115AQ Coil spring   2 PR-UC7+0YD
1 3Q0511115AR Coil spring   2 PR-UC7+0YE
1 3Q0511115AS Coil spring   2 PR-UC7+0YF
1 3Q0511115AT Coil spring   2 PR-UC7+0YG
1 3Q0511115BA Coil spring   2 PR-UC7+0YH
1 3Q0511115BB Coil spring   2 PR-UC7+0YJ
1 3Q0511115BE Coil spring   2 PR-UC7+0YK
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511005
There's also aftermarket front springs available for increased ride height.
Edited by Carlston
As you can see in the below chart, there are three different front buffers with heights of 55mm, 70mm, and 90mm.
The 55mm front buffer is for sports springs, ie. lowered ride height.
The 70mm front buffer is for standard ride height.
The 90mm front buffer is for increased ride height.
Superb MK3 buffers for front shock absorbers
3 1K0412303B rubber stop for
shock absorber
70mm 2 PR-G01
3 1K0412303F rubber stop for
shock absorber
55mm 2 PR-G02
3 1K0412303AA rubber stop for
shock absorber
90mm 2 PR-G03
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/4/411/411000
55mm front buffer
110068001 TOPRAN Front Axle Left, Front Axle Right Height: 55mm Rubber Buffer, suspension 110 068 cheap
70mm front buffer
32853 MAPCO Front axle both sides Ø: 56mm, Height: 70mm Rubber Buffer, suspension 32853 cheap
90mm front buffer
117186001 TOPRAN Bump Stop, axle beam 117 186 cheap
As you can see in the below chart, there are two different rear buffers with heights of 112mm and 127mm.
The 112mm rear buffer is for sports suspension, ie. lowered ride height.
The 127mm rear buffer is for standard ride height and increased ride height.
Superb MK3 buffers for rear shock absorbers
11 5Q0511357H Stop buffer 127mm 2 PR-1JA,UC7
11 5Q0511357J Stop buffer 112mm 2 PR-1JC
112mm rear buffer
116282001 TOPRAN Rear Axle Left, Rear Axle Right Height: 112mm Rubber Buffer, suspension 116 282 cheap
127mm rear buffer
116281001 TOPRAN Rear Axle Left, Rear Axle Right Height: 127mm Rubber Buffer, suspension 116 281 cheap
Edited by Carlston
